Hello Canadagoose.
It looks like your Beagle Pup came out pretty good as
http://www.rcgroups.com/forums/showpost.php?p=14231939
http://tjlewis1.rchomepage.com/forum/viewtopic.php?t=69
indicate..
How did it fly? Are you flying it with skiis now? If you think it was originally for .074 where did the original plan come from? Is that a variation of the RCM #359Beagle Pupplan from the RCL-68 issue (whatever RCL is)?
ORIGINAL: canadagoose
I'll say first off that i don't know anything about powering a plane electrically but want to start in on electrics by finding a suitable motor, speed control and battery for a small 34" span 26" long plane that i'm building called the Beagle Pup. I think the weight should be around 22 oz. Attached is a photo of the plane so far. I think it was originally designed for a Cox .074 to a .10 glow engine with a prop size of 6 -7 inches. This plane will be going on some foam floats for float flying. Any suggestions would be much appreciated. Thanks.
