Whitch Airtronics 2.4ghz reciever for 3D foamies?.
Hallo all,
I will be buying the SD-10G from Hobby People and i will be using it for Pattern,3D and indoor 3D foamies.
I will be buying the Fancy Foam MX-2 and as i read the Spectrum AR6100 micro reciever is only compatible with DSM2 systems so if i want to use my SD-10G for flying my foamy i have to use an Airtronics 2.4Ghz micro reciever as the AR6100 will not work with my SD-10G,is this soo?.
Can you guys tell me whitch recievers are you guys using for 3D foamies with the SD-10G?.
Thanks Greg.
