RCU Forums - View Single Post - earthquake 8e center diff problem
Old 12-20-2010 | 09:37 AM
formula87's Avatar
formula87
Default RE: earthquake 8e center diff problem
ORIGINAL: Allnighters
Got my earthquake 8e (thanks Kurt) and the center diff is rubbing the aluminum frame. The diff moves back and forth a little. Should I try to shim it or file the plate a little?
I thought the same thing on mine and I took some material out of the hole the gear pokes thru It was making a noise upon accel and I thought it was the gear hitting the opening but came to find out it was the front diff shredding the gears after I tried to take out a tree ,,,,,,,,, call Kurt and he can Help you out.
