Multiplex users
Calling anyone who uses Weatronic with Multiplex Profi or Evo Tx. I need volunteers to do a simple test. Both my Profi 4000 Tx have the same fault with Weatronic, and numbers provided to me by Weatronic and Multiplex predict exactly the fault I am getting, but Weatronic won't listen and just keeps telling me my transmitter must be faulty. I contend there is a flaw in the Weatronic software which affects all brands of Tx, it is just more obvious with Multiplex because of their longer pulses at the default setting. I need people to try a simple test and see what happens so that either we can prove I am right and we can go to Wea and make them listen, or prove me wrong and start to work out why two of my tx do the same thing!
I should stress that the alleged fault has no implication for flight safety or the integrity of the system.
So, are there any Multiplex/Wea users?
The test will also work with JR or Futaba Tx, they just need different % travels to be used, which are above the normal 100% travel. If any JR or Futaba users would like to also try the test, very easy and takes only a few minutes, I would be most grateful as it would help to prove or disprove the problem.
Harry
