RE: Giant scale setup w/SD10G and 10CH RX
Next thing I program is my exponential. It is right after the D/R so it is a nice logical step in the flow of the SD10 menu. You will notice as you cycle the 10/11/12 (I will now call it the rate switch) switch it shows its' mode position on the display as 1, 2 or 3. You can set each rate 1, 2 or 3 with desired expo, a nice thing to have. I like to set my low rates with 20 to 30%, my middle or #2 rates with 25 - 35% and my high or 1 rates with 35 to 45% expo. If you want the center movement of your stick to be the softer portion, you will use positive value numbers. If you want to the stick to be more sensitive around center then use negative values.
Jeff
