RCU Forums - View Single Post - Best Way to Attach a Canopy
Old 08-06-2003 | 03:41 PM
Blackie's Avatar
Blackie
Default Best Way to Attach a Canopy
I try to use screws when I can. What I do is glue in small thin square piece's of ply on the back side of the balsa if applicable, then drill holes in them. I then put thin ca in the drilled holes to harden the wood, then paint the wood to match the interior. After all of the above is done I then use either automotive trim tape or RC/car trim tape depending on color and application.
Blackie
