Throttle lock switch odd behavior
I programmed switch D to activate the throttle lock feature on my Aurora 9 V1.07(2). It works properly except when I first turn the transmitter on and go into transmit mode, the throttle lock is not on even though the programmed switch is in the correct position. Also, the "Plane" icon on the screen will allow throttle lock to be engaged by pressing for two seconds which it normally does NOT do when a switch is programmed for throttle lock. After I cycle the programmed throttle lock switch one time everything works properly. This behavior seems odd to me. As a safety feature for some rather large electrics, I wanted an automatic (engaged at power on and transmit) throttle lock that I didn't have to remember to set. For some reason the processor appears to ignore the position of the programmed throttle lock switch until it's actuated at least once. As far as I can tell, it doesn't do this on any other control. Why does it work this way and is it possible to change this behavior?
