ORIGINAL: Antique
Nothing will happen if you loosen the 4 screws on the cover.../The inlet needle under the diaphragm is opened when the diaphragm pushes on the end of the lever...Blowing into the tank won't get fuel past the lever unless you can blow 10 lbs pressure...No one can....
<hr />
Sometimes just getting the fuel in the pumping section will get a dry carb going. Been there...done it. Now once he gets the engine running good...leave a little fuel in the tank in the airplane. Toni Clark explaines why. I done it....will continue to do it....because it makes for easy restarts after a week or more. It keeps the carb damp from the fuel.
Yes and sure as I said it...most will not even try it. To them guys...I do not fell sorry if you crank your arm off. Capt,n
