RE: help removing engine
In this order remove the following: 1) spinner and prop, 2) unplug fuel and pressure lines, 3) muffler, 4) needle valve, 5) cowl and simulated exhaust stacks, 6) disconnect the throttle linkage, 7) remove the 4 phillips head motor mounting screws. Reverse order to reinstall engine.
