ORIGINAL: BuschBarber
I stated that it could and has been done using one of the Programmable Mixers included with the DX7. I friend of mine recently used the Rocker Switch, on the Right side of the Antenna, to control the mixture for his RC Boat. The same principle can be used for Throttle Cut.
A quick call to Horizon would result in learning the exact steps to follow. There are also other threads that cover this same issue.
A Google Search might also yield the answer. It took me two seconds to bring up the following thread. There are numerous others.
http://www.helifreak.com/archive/index.php/t-27970.html
Yes Dear BuschBarber i read that but this is not a method of accomplishing the results wanted by richardgerardi.
It is a general aproach to try to get the results.
You did not tell him (or us) "how to do it" ; you gavesome idea how we miht go around to try to do it.
A big differnce that does not yield the results wanted.
I am not trying to have any confrontation. I am simply stating my arguments in a friendly discussion.
No discussions are possible if we see things the same way..
I still have not seen a description of steps to take that ends with the desired results .
Zor
