Wow !
It looked like post # 2 of that thread pointed to the examples. No ??????????????
Here is the solution posted on the Soar.com/Spektrum link....
Implementing a Throttle Kill function
There is no throttle kill function provided with the DX-7, instead there's 'Throttle Idle Recovery'.
For those who prefer a traditional Kill function, here's a solution which works off the MIX switch:
•Use PMIX-5 or PMIX-6
•mix THRO->THRO
•SW=MIX
•Rate = -100 / -100 (note both negative)
•Offset = -125 (note negative)
Note 1: use only PMIX-5 or 6, otherwise the kill setting will vary with idle trim.
Note 2: The kill position is adjusted via Offset.
[sm=spinnyeyes.gif]
