Second Airplane
Just my two cents, but I went with an Extra 300S 58" w/s, 60 size as my second plane. It is an ARF from Vector Flight. I have only put about 6 flights on it thus far but it is really easy to take-off and land. In fact the first and second flights on it were dead-sticks. The first was not so good but no damage and the second was a perfect landing. You can bring it in either fast or slow........it flies slow really well. If you get something like it just set your throws to 1/2 or less of what is recommended and you should not have any problems. After you get better with it then start to increase the throws in small increments. If you haven't done so you may also want to ramp up the throws on your trainer, it'll be a little more interesting to fly.
