RCU Forums - View Single Post - Horizontal tail (beginner question)
Old 01-11-2011 | 10:36 AM
Franco2fly
Default RE: Horizontal tail (beginner question)
Mine is a steel rod, at 25% back from the LE.  The second movable aft rod is about 3 inches back.  The bottom of the inverted "L" (picture an upside down L with two steel rods one is the pivot  and the back of the short leg is a screwed in steel rod.  This allows each side to be moved independent of the other.  My "L's" have an angle at the top for additional rigidness.
Here's a shot up the rear where you can see the control rods going forward down at the bottom.  Look closely and you can also see where the aft rod is threaded:
As you look across the stab and in the upper left the left aileron is visible.
KKKKFL
