RCU Forums - View Single Post - Work Bench & Model Room
Old 01-11-2011 | 06:35 PM
JRM23
Default RE: Work Bench & Model Room
TedMo,
Thank you for your input. I can tell you that I will make the building table, at least 24" in depth, I think it will be 36" in height and at least 10' in length. I have thought about making it out of alum. with adjustable casters on each leg, so I can make sure that the table is level in all direction. I am not sure of what I will use for the table top.
I really am not sure of what all I should buy as power tools, but i do really want to set this room up with everything that I could use or need.
I do plan on using the wall space to store airplanes, or maybe to hang them from the ceiling. I am also going to put up a peg board, as you would see in a store, so i can keep all the part all nice and neat and I will be able to find them.
Again, thank you for your help and your advise,
John
<br type="_moz" />
