Ok , that being said,,,, we can all go home and watch the three stooges,,,,,,, yeee Haaaaa
ORIGINAL: bevar
And then presto...it's nothing more than cannon fodder.
>>Its been just three weeks since China unveiled its new J-20 stealth fighter, and already the U.S. Air Force has plans well underway to defeat the mysterious plane from Chengdu.
No, the Pentagon wont be buying more F-22 Raptors from Lockheed Martin. Instead, the U.S. militarys main flying branch has turned to an older jet that, with upgrades, could prove to be an even better J-20-killer than the newer, more expensive F-22. Thats right: the Boeing F-15 Eagle, one of the stars of the 1991 Gulf War, is quickly shaping up as Americas main countermeasure to Chinas new fighter for the next 20 years.
To be fair, the F-15 and F-22 (and, later, the F-35) will probably usually work in teams. But the F-15, with its better sensors, could prove to be the backbone for U.S. and allied forces in any Pacific dogfight.
The magic is all in the Eagles nose. Compared to the angular, stealthy F-22, the totally non-stealth F-15 has a more capacious nosecone that can carry a larger radar. The larger the radar, the more likely it is to detect the J-20, despite that planes potentially very small frontal radar cross-section. The F-15 also routinely carries more fuel and missiles than the F-22.
The Pentagon has begun fitting new, electronically scanned Raytheon APG-63(V)3 radars to around 175 F-15Cs dating from the 1980s. In a few years, the 220 90s-vintage F-15Es normally optimized for ground attack, but also capable of air combat will get new APG-82(V)4 radars, also from Raytheon.
To pay for this electronic transformation, the Pentagon has set aside some of the roughly $34 billion it will save by shutting down several redundant Air Force headquarters and command centers and delaying production of the troubled F-35 stealth fighter-bomber.
The F-15 initiative was important enough to warrant mention in Secretary of Defense Robert Gates announcement of Pentagon cost-cutting measures last week. Gates said the modernized F-15s would be viable well into the future. That might come as a surprise to some observers, considering that just three years ago, an F-15C disintegrated in mid-air, nearly killing the pilot. After that accident, some observers declared the F-15 unfit for duty, for reasons of age.
But the Air Force determined that a poorly made part, rather than age, caused the F-15 disintegration and that with repairs and good maintenance, F-15Cs could keep flying until at least 2025, and E-models until 2035. But those are just planning factors, said Col. Gerald Swift, the Air Forces top F-15 maintainer. Right now, there is nothing life-limiting on the F-15. It is a very well-designed platform.
The sprawling U.S. Air Force base in Okinawa, Japan, will be the main home of the modernized F-15s. The first batch of F-15Cs with the new (V)3 radars arrived in December. By 2013, there will be 54 improved F-15Cs at the Pacific outpost, flying alongside a rotating force of 12-18 F-22s.
The Air Force is working on new tactics to blend the F-15s and F-22s into a single team. As currently envisioned, the F-15s would fly with extra fuel tanks and AMRAAM missiles and with radars blaring, while the F-22s, carrying less gas and fewer missiles, would turn off their radar and sneak up on the enemy for ninja-style jabs. Our objective is to fly in front with the F-22s, and have the persistence to stay there while the [F-22s] are conducting their [low-observable] attack, Maj. Todd Giggy, an F-15 pilot, told Aviation Week.
This teaming will get a big boost starting in 2014, when the Air Force finally installs secure data links on the F-22, allowing it to covertly swap targeting info with other planes. Even then, the F-15 will have a better radar and more weapons and endurance, making it the Pentagons preferred J-20-killer and the biggest reason why the United States hasnt yet lost control of the airspace over the Pacific.
