Yea that's not so easy to do because in our club and probably most clubs guy's hide then poke out and shoot and go back into hiding so that's why to me it don't matter how long it takes to reload because you can't shoot something that's hidden so it don't matter your fire rate at all if it's 3 seconds or 9.
Way i see it since the tanks are the iR is fake and non realistic set all tanks to the same # and it will even things up and make for better battles.
Agreed. If things are to be some what fair using the current system, everyone needs to be set to the same level of protection and reload times. If a club decides to keep the weight classes, I still think the solution is some sort of speed regulator to set your tanks to fast, medium or slow depending on what your weight class.
