RCU Forums - View Single Post - GMP'S GoldWing MX2 The Green Machine
Old 01-23-2011 | 04:46 PM
kerwin50
Default RE: GMP'S GoldWing MX2 The Green Machine
I worked on my landing gear though it was so simple as most of the work is already done.
I started by bolting the axles to the gear.
Next I put the 1st wheel collar on the axle leaving just enough space to be able to slide the wheel pant on. I also put the set screw poing down.
Then I put the wheels on. The wheel fit really well. not to tight or to loose. of course next was the outer wheel collar and once again with the set screw pointing down for easy access.
It was only a matter of bolting the wheel pants on an the job is done
ID:	1551870   Click image for larger version
ID:	1551871   Click image for larger version
ID:	1551872   Click image for larger version
