HS-5985MG Resistor Change for R6014FS
Ihave 4 5985 (V1.05) servos that are incompatible with the Futaba R6014FS 2.7V signal voltage when using Y connectors. I understand there may be a resistor change to make them work correctly.
Would it be possible to get the details of the required change via PM. I am capable and equiped to perform the required re-work.
Thanks.
