RE: Yellow Aircraft F-22 ARF Assembly Thread
Shaun,
Just found a possible weak spot you can avoid during this build. Before you put your nose gear in place a cf tape piece on the top and bottom of the nose gear former at the glue joint of it and the fuselage. After an "off road" excursion this weekend the nosegear former popped loose from the fuselage.
