RE: Shorts Tucano T1-120
Hey Baldwin
Just a question on the forms in the fuse while I was looking at the above pic. The glue seems a bit tacky still. Not sure if it is the hot weather and it was sitting in the back of a car at the field but was not sure. Were yours glued ok. I looked to see if needed to run some glue round them but there is plenty around all the formers I can see. As per the pic you can see the glue.
Was not to clear on your canopy attachment method.? I was thinking of making a tray with a tongue or dowls at front and strong magnets at the rear to hold it down. Or a commercial spring loaded latch on either side at rear.
