RE: Backdraft 8e Battery upgrade help
There is no diff between the 1/10 and 1/8 scale batteries the Venoms I use are the same size as the stock 8e lipos so you should be fine 1/10 scale batteries and 1/8 scale use the same mah and voltage and c rate. Some may slightly bigger or smaller just measure the stock lipo to make sure the new ones will fit and go from there............
