RE: Trouble with Meister elevator L/E. (Zero)
I'm confused, your title says leading edge, but your last post speaks of trailing edge.
For trailing edge, I add the one of the sheeting and run it 3/8 past the ribs. I then come back and sand that sheet to the same angle as the ribs. After sanding, clean it up to be as stright along the trailing edge as possible. Next, glue the other side sheeting on and trim flush along the trailing edge, with the first sheet, and you will be good. You can come back and sand a little sharper angle on it, but not necessary.
hope this helps.
Jeff
