RE: Evo 61nx vs O.S. 65AX
Keep in mind that rpm numbers on the ground don't tell you much in regards to actual performance. You need onboard gear to tach the engines while in flight to have meaningful numbers once the prop and engine have reached an efficient state. Otherwise, static rpm doesn't tell much about real life performance.
