RCU Forums - View Single Post - Evolution 61 Stalls going Vertical
Old 02-04-2011 | 07:37 PM
nitro wing
Default RE: Evolution 61 Stalls going Vertical
the above is the simplest and most common test. start the engine and let it warm up for a minute or so, then advance to full throttle and hold the aircraft steady and raise the nose into vertical position, if the motor gains rpm quickly and then dies, adjust high speed counter clockwise by 1/4 turm max. If those adjustment to not resolve the issues, then looking into the other above posts is recomended.
