RE: Horsepower War A Brewing!!!
Find it hard to keep my mouth shut here..
Lunatik's dyno is almost like the 'inofficial LS benchmark dyno' because he dynoed a lot of LS engines, and the best way to compare engines it so run them all on the same dyno.
If somebody else would have done the same as Lunatik, and tested most of the available engines and pipes, then they would also have a good benchmark dyno. Even if the numbers were totally different on the other dyno, you could still compare results of different engines.
Not all dyno's are equal, so comparing results from one dyno with results from another does usually not give the same numbers. If all engines are dynoed on the same dyno, that's the best way to compare the engines.
How can this be so hard to understand?
