RE: Redcat Racing Rampage MT V3- Let's review UPDATE: 2/24/11...gone...
Sorry to hear that you are giving up on the MT that gear cover did'nt have enough vent holes and that let the gears get hot and made the loctite let go leve the cover off and clean the threads off with brake clean and put the gears back on use red loctite and install the nut on and let it set up for 30 min do you have a shim on that shaft so you can tighten that nut good and tight without binding up the bearing Jim
