RE: 1/10 NB Crawler
so i made another motor mount, with a different gear, with the right pitch, the only time the gear works well is when the battery is at its lowest... however when the battery is full power it makes a loud ratchet noise, it moves. before I put it together i had the gear running pretty freely in a straight line paralel to the other gears, i'm thinking i need to match up the gear right, drill out the gear hole, and find the same thickness screw, and bolt it in there, right now i'm using the stock pins in a hole like 1/32 of an inch thick of room to move around. but even if i hold the gear in the right spot, it still makes that ratchet noise. I think its the wrong pitch compared to the other gear. fits wrong maybe
