RE: Help! - Radio problems in flight
Alan,
Thanks for getting back to me so quickly.
1) Yes, the silver part of the antenna does touch the fuse. I'll correct that.
2) Good to hear that power isn't a problem. I never got a low voltage alarm.
3) I will go for that piece of mind.
Can I more questions?
4) Why would having only the tip of the antenna outside the fuse be better than the whole 'thicker' part?
5) when I go to install the Optima 9, do you have a suggestion on placement? Top and side of the fuse? Side and bottom?
Thanks again.
Flyingtomg
