GP Super Sportster 40 engine install help!
Im going to install either a Super Tigre 45 or OS 46AX in my Super Sportster... question is has anyone succesfully fitted one of these engines in without basically hacking the whole front end of the engine compartment apart to make it fit?
The engine right now is sitting right on the forward edge of the mount, the drive hub has barely come through the required 3mm, and I will need to take lots of wood out of the front end so the carb does not sit against the fuse and on the other side I will need to dremel away a good chunk of the front just so the throttle arm will move...
I don't even know how I wuld get the super tigre to fit without literally hacking the front end of the plane apart...
Anyone else experienced this with this arf, or am I blatantly doing something wrong here....
