RE: Latency in Elevator Halves
I don't mean to speak for Mike, But the programming allows for an Elevator 1, and Elevator2 label that you can assign for whatever channel you choose. Same with aileron, and I believe Throttle. This allows you to not have to use a P-mix and it helps make it easy to program. I have tried to see if there is a difference with the slight lag by changing elevator 2 to an AUX channel and assigning a mix between Elevator 1 and AUX. There was no difference. They behaved the same.
