RE: Byron AT-6 Build /Rebuild
jeff , i did away with the nyrod setup went to a pull-pull for the rudder and linked the rudder to the tail-wheel via linkage. . if you look at the side view it looks like only one push rod is being used for the elevator. they have to cross each other.
