RCU Forums - View Single Post - Byron AT-6 Build /Rebuild
Old 03-02-2011, 12:52 PM
JeffH
My Feedback: (43)
Default RE: Byron AT-6 Build /Rebuild
Your ball link locations netted about the same separation distance as a block under one servo with less angular change at the exit point. One suggestion i have it to make sure you have some sort of pushrod supports about half way down the fuse. Those pushrods will vibrate like crazy with a single cylinder engine. They will actually hit each other if the right resonance is achieved.
