Jetcat Mini GSU
I've just received my new Jetcat mini GSU and the connection options have me all confused.
In my package I have one 6 pin cable which plugs into a supplied I/O board (the same as the one supplied with the P-20). I also have an 8 pin cable (no I/O board to fit this). As far as I see I can only use it if I plug it straight into the P-20s ECU, which is a bit of a pain.
I can't use the I/O board to connect it to the V10 ECU as it only has one Minibridge (the new connector) and one RJ45. Therefore I can't plug both the ECU and GSU into the I/O board at the same time.
The literature about the P100 says that you use the 8 pin cable with I/O board for V6 type ECUs but I don't have an I/O board that fits the 8 core cable so can't use it with my old P-80 either.
Am I supposed to have more parts supplied with the Mini GSU than I have, or am I supposed to buy them separately? What other new cables/connectors are available (if any)?
