RCU Forums - View Single Post - Engine Problem
Old 03-23-2011 | 08:35 AM
MetallicaJunkie's Avatar
MetallicaJunkie
Default RE: Engine Problem
ORIGINAL: scooterinvegas
ORIGINAL: MetallicaJunkie
what is that used for in regards to fuel taks
It is a pressure/vac pump with gauge. You can check the the whole fuel system from the carb line to the muffler in 10 sec in the plane. If you find that the system is not holding, it is easy to identify the problem by either bubbles or leaking in the system.
how much does it cost?
