RCU Forums - View Single Post - Fixing a twisted wing
Old 03-27-2011 | 11:49 AM
dbacque
Default RE: Fixing a twisted wing
There's nothing wrong with using the covering to correct twist, I use that method for truing every wing I build. And it holds too, especially with MonoKote which has a higher tensile strength than other coverings.
Sounds like you're doing everything right but it can take several cycles to finally get it straight. I've taken more than 3 degrees of twist out of the wing of a Super Kaos 60 this way.
But personally I wouldn't include any washout. A Kaos wing should have absolutely no twist.
Dave
