RCU Forums - View Single Post - harding the diff gears
Old 03-30-2011 | 11:14 PM
nlovern
Default harding the diff gears
Hi,
I have read alot about the diff gears going bad on the redcats and i was wondering if anyone knew what the gears are made of? cast steeel or cut from stock>
I know you can heat treat metal in an oven and with a torch and you can also dip steel in liquid nitrogen for a few days to harden up steel.
Would thiss work? if my gears go out on my EQ 3.5 i will try to heat treat the new ones.
Think out of the box
