backdraft 8E issues
Hi all,
I have had my backdraft for less than two weeks. Last night I wanted to adjust my brake drag force. I held down the button on the cars' on/off switchand turned the unit on. After two beeps/flashes, it took off like a bat out of hell and hit a board and flipped over, all the while it was running at full throttle. I picked it up and turned it off.
Now when I turn it on, after it flashes a couple times, the wheels spin at full throttle with no input from the transmitter. While this is going on, I am able to make the front wheels turn right and left. If I push the trigger to reverse it does go into reverse, but I can't get the wheels to stop spinning. If I flip the throttle reverse switch the wheels do switch direction.
I did try to re-bind with no luck.
Has this happened to you before? Can you help, give advice, please?
