sounds like you tried to program the settings manually(with the remote)
its not an easy thing to do.
and chances are, you didnt hold down the "set" button long enough and recalibrated the ESC instead of programing it.
follow the ESC's manual for recalibrating the ESC.
you can remove the pinion gear, or loosen the motor screws and move the pinion away from the spur to make sure you dont have it take off on you again while trying to program it.
in case you dont have it, here is a link to the ESC's manual:
http://www.hobbywing.com/upload/manu...13-80-v2-e.pdf
