RE: Enya .60XF trouble when running hot ?
Don't clean the piston and cylinder, that is just asking for trouble as you will loose the all important castor. A simple cleaning of the carb is probably all it takes.
If you do take it apart then also check that the conrod is moving freely on the wristpin. Castor can freeze this up and then it wears on the piston instead.
