RCU Forums - View Single Post - Cleaning an engine
Old 04-04-2011 | 07:24 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: Cleaning an engine
ORIGINAL: Clmbngfrk18
I'm having a problem with my 1 way bearing slipping. I have less than 1/2 a gallon run through the engine using traxxas fuel. I cleaned it the other night and had it running for a few moments before shutting it down. When I went to run it this weekend it was slipping again. Thus making me want to clean the whole engine. I was just going to use carb cleaner. But thought I'd ask here for any other suggestions.
Also any suggestions as to my bearing is slipping so much already would be appreciated
If you search for "top fuel is junk" you'll find a few threads dealing with how bad the fuel is. Switch fuels. Blue Thunder, Odonells, Byrons, Trinity... all good fuel. Traxxas is terrible.
Next: soak your one-way clutch in denatured alcohol and clean/blow out thoroughly. Next, sand the starter shaft on the engine with 400-1200 grit sandpaper to rough it up a bit. Clean it well and reassemble with the One-way clutch going in DRY. Oil makes them slip. Sanding the shaft gives the one-way clutch something to bit into to prevent slippage. Works every time for me.
Excessively rich fuel mixture and/or too much oil in the fuel causes slippage most often. After a LOT of slippage, the shaft gets polished so cleanly that the one-way clutch wont grab well. If this all doesnt work, its time to replace the one-way clutch and starter shaft. Its best to replace both of them since they wear into each other and the tolerances being pretty tight.
