ORIGINAL: w8ye
I was thinking that a Enya #3 was pretty hot.
If the bearings are smooth and tight, don't take the engine apart if you do not need to.
I've seen references to the ENYA #3 and the OS#8 being roughly equal, and the Enya plug was what I used when the engine was in my Senior Telemaster.
I don't want to hijack my own thread, but....
From Enya website:
No.3 | HOT | For standart engines
It is supported all 2 cycles 4 cycles engines. | EP00003 | |
No.4 | MEDIUM-HOT | For standard engins
It is supported all 2 cycles 4 cycles engines. | EP00004 | |
No.5 | MEDIUM | For hot engines
A helicopter or a car to use in high temperature, high speed | EP00005 | |
No.6 | COLD | For competitions
For high speed, long ranges with a high compression engine | EP00006 |
Cheers
on the bearing info
