RCU Forums - View Single Post - repair question
Old 04-14-2011 | 12:44 PM
Minnreefer's Avatar
Minnreefer
Default RE: repair question
Thanks guys, I will add some plywood on the outside. I should have done a few things different, I made the new plywood on the inside, but I should have made it a little longs, I was not really thinking. I cut it there, mainly because that is about where it broke and I did not want to redo the servos (lazy) It is basically built the same as when I got it, I just want to add a little more. I am worried about the wooden mounts breaking off again (all 4 broke off with the wing, and the wing just floated down gently, while I was trying to use the elevator to bring the wingless body up from it's dive )) )
Mody, I believe most of the planes that Greybeard (Gene) has are Kaos, or more "vingtage" pattern planes 1 might be a birdie.
