ORIGINAL: PDR200
So far I've only done a few test runs
I have some small problems to fix. Then I should be able to do much more testing and post some accurite data.
My main problem is at low power settings (below 40%) I have flame thru the NGV same as Chrigui?? but when power increases combustion goes back inside the combustion chamber.
Does anyone know what causes this problem? [:'(]
More info coming,
Cheers,
hello .. my problem was the lubrication fluid (front bearing) sucked by compressor due to clearance between compressor base
and the diffuser.... solved later ...
