RE: Nitroplanes Seawind
Hi
,i checked the CG ,and added alittle lead ,so now it is at 37 mm from LE with full tank, and added max EPA on the elevator so i have as much as possible up elevator.
I will test it again tomorrow ,and see if i can avoid the bouncing.. I hope i can learn to take it off! It was very cool to taxi around with some speed ,and if i can get it to fly it will be a joy!
There was flat water with no waves so it is not waves that make it bounce either. Maybe a lot of up elevator can hold it still.
