RE: Exhaust temp vs solder
Can't braze with an ARC welder. Brazing is joining by melting the brazing rod to hold the two pieces of metal together. Generally brazing is using brass to join steel. Welding is fusing the two pieces of metal together with a like metal as the electrode.
