RE: Band saw or scroll saw
A bandsaw will give you a beter overall cut with the use of guides etc. and will handle thicker materials. The scroll saw will allow you to make inside cuts in areas that a bandsaw will not. I have both and use them both regularly ,but if you had to choose only one it should be the bandsaw .
