22lbs weight..
11lbs of thrust..
as long as your
lift to drag ratio is better than 2:1 it will fly...
(a Cessna 150 has an L/D ratio of about 7:1)
Unless your scale aircraft looks like the apollo Command Module (L/D of 0.368) then you should be fine..
Seriouslythough.. that should be a nice combination of plane and motor..
