RE: Help...
You can try a 50/50 mix of ammonia & water. Wet out the side opposite the warp and weight the ends down while supporting the middle. What you want is to actually overweight the ends so as to create a slight bow opposite of the bow that is there now. Leave & let dry, remove the weight and see what you have. Short of cutting into the aileron, this is about the only option.
