RCU Forums - View Single Post - Best glue type
Old 05-02-2011 | 12:35 PM
KitBuilder's Avatar
KitBuilder
Default RE: Best glue type
You need to pick your battles regarding weight. Some areas are not worth skimping on as you found out. Generally for "most" builders the repair will weigh more than if it was done properly during construction. With arfs your usually stuck but you can do things like adding tri-stock, etc to that area..
