Firewall Strength
DogEater:
If you have effectively inverted the designed mount, and the 1.20 is within the recommended range, you should not have any worry.
That being said, it looks like the engine mounts on the wooden beams. If yes, I'd cut them off flush with the firewall and use a soft mount for the engine, bolted to the firewall.
Bill.
